Or trim that copper bit down/alter the pipework?So it looks like the new tail at 50mm will be longer and I need to cut it down. I understand the need to get it perfectly square so would I be better off buying the plastic version which will be easier to work with. ThanksView attachment 400894
You're welcomeBrilliant, thank you for your help
I would get some decent ones, no idea on Aldi ones as I've never used them. You may be able to use rubber, but we've only dealt with fibre and you used to be able to get Nylon onesSo fibre not rubber. I have these but are all fibre washers equal, these are a set from Aldi.
As I am going to the proper plumbing supplies place would I be better off buying a few "proper" ones
Yes thanks I will be getting some proper fibre ones from the plumber merchants thenYou're welcome
There is no way I am touching that push fit stuffOr trim that copper bit down/alter the pipework?
Thank you very much.Your measurement of the threaded tail doesn't include the thickness of the cistern or the seal inside the cistern.
You will very likely find that your new valve will fit without needing to cut it at all.
There will be a seal between the isolation valve and the threaded tail of the valve,and you will very likely need to fit a new one.
Ok great thanks. I might just buy the version with the two sizes as I am not near the house to make a trip and then find the 1/2 won't fit.The thread of the valve tail in your picture looks like 1/2inch BSP to me.
Right, seems a bit of an odd measurement then.The 15mm measurement in the pdf drawing would appear to be nonsense, having never seen a float valve thread with a 15mm diameter, as it appears to depict.
I see that's my confusion then 1/2 and 3/8 refer to the thread size not the actual width of the pipe. OopsThe pipe size is irrelevant, only the thread of the float valve and the isolation valve needs to be the same.
Correct ,and believe it or not 1/2 inch BSP thread is nowhere near 1/2 inch in diameter ( it's nearer 3/4 of an inch) !!I see that's my confusion then 1/2 and 3/8 refer to the thread size not the actual width of the pipe. Oops![]()
