Replaced WinkHaus door lock strip, stiff already
25 May 2014
Sussex
This is about 6 weeks after fitting. Its a two roller, three hook Scorpion XL3, and feels obstructive as the deadlocking starts, i.e. the hooks start coming out the frame. It feels the same when unhooking, and behaves identically when the door's open.
I think its got progressively worse since fitting.
The supplier suggests silicone spray, and I'm sure I was old years ago that graphite was a better lubricant.
How shall I deal with it?
Many Thanks - braniff
Have you removed it from the door and tested it?
Sounds like it's binding somewhere, could be twisted or too tight or it could be a faulty lock itself
Impossible to tell from here , you will have to fault find by process of elimination
Start by removing it from the door and testing it's operation on the bench
Is it stiff to operate when the door is open?
Ie can you raise handle to throw lock and turn key, with ease
