replacement cooker, wiring question
5 Dec 2007
Staffordshire
When I had my Kitchen done the cooker was moved and the fitter ran a cable from the main cooker point to a double socket (one for the gas hob ignition and one for the cooker) and then ran a spur from that double to another single for the extractor fan.
The cooker is now playing up and I want to replace it, simple enough but..
If I go for one which uses a 13amp plug then no problem it just plugs in the existing socket.
But i'm looking at a more powerfull one which requires hard wiring.
Ok here's the question the hard wired one will just be wired into the old cooker point, but can the extra sockets for the hob and extract be left or will then have to be rewired to a different circuit?
Thanks. Gavin
Cookers should be wired on their own circuit, generally using 6mm² cable. What you might be able to do is incorporate your double socket as part of the kitchen ring. If its a radial to can add it in - make sure you use the right size cable it could be 4mm².
The single socket for the extractor could be added to the lighting circuit via a 3A FCU.
Incidently when you say cooker point I take it you do mean cooker connection unit rather than cooker control unit.
by cooker point i mean the big junction point behind the cooker which is switched by a standard cooker switch plate.
OK that's the cooker control unit. There should also be a cooker connection box from where you then connect direct to your cooker. This is also connected to your CCU with 6mm² cable and is usually sited behind your cooker.
As your CCU has a 13A socket the cooker circuit should also be RCD protected.
That sounds about right. here's a little sketch
and this is the proposed
Would that be OK.
I should also say that all the sockets/connections are hidden under/beneath the cabinates except the switch
