Hello all. Cooker question if you could cast an eye over it. I'm replacing a gas oven for an electric one. Now there is from the previous occupants still fixed in the 45 Amp cooker switch (+13 amp socket) with 6mm T&E to a 45 amp mcb on the CU. Currently mcb switched off but hoping to re-use this to power the new oven (which is rated at 2.2 Kw I think) with the 13amp socket serving the ignitors on the gas hob. My question is as this oven is okay to run from a 13 amp socket, I haven't any spare as the one on the cooker swith is powering the gas hob ignitors can I take another socket from the 45 amp cooker switch (either hard wire into a 13amp FCU or a normal 13amp plug socket). Also does the cable from the cooker switch to the oven socket/FCU have to be the same size as the one feeding it from the CU (6mm in this case).
Thanks very much
Thanks very much
