I am installing a new electric oven and gas hob in place of an old electric oven and hob.
old setup
cu 32amp mcb > cooker switch with socket > outlet panel (6mm wiring) > oven.
new oven is 2700 watts
proposed setup
cu 32amp mcb > cooker switch with socket > outlet panel (6mm wiring) > unswitched FCU with 13amp fuse > Double socket (2.5mm wiring) dp
13 amp plug with 3 amp fuse for hob
13 amp plug with 13 amp fuse for cooker
Does this sound acceptable? Not sure if The hob/oven wiring should be fixed, appliance instructions indicate otherwise hence the above configuration.
comments/guidance welcomed.
Keith
old setup
proposed setup
Keith
