    Dismiss Notice
Running a spur off a cooker circuit?
Discussion in 'Electrics UK' started by Johnday, 22 Aug 2013.
  1. Johnday
    Johnday
    22 Aug 2013
    10
    Thanks Received:
    Essex
    Country:
    I am installing a double oven (20 amps) and a separate hob (32 amps) I want to run a 6mm twin and earth from my consumer unit with a 45amp MCB to a junction box, then run a cable (in 6mm) from the junction box one way to a cooker outlet for the oven and another cable (in 6mm) to another cooker outlet for the hob. Both cooker outlets will have 13 amp sockets.
    Would this be OK?
    If not would it be OK in 10mm? Or should I just run 2 separate 6mm cables from the fuse board? (I have 2 spare slots left).
    I also want to spur of the oven outlet to a 13amp socket to run the dishwasher.
    Please advise.
  2. Sponsored Links
  3. EFLImpudence
    EFLImpudence
    7 Jul 2010
    35,089
    Thanks Received:
    3,895
    Retired to:
    Country:
    Portugal
    You can of course design circuits for whatever you wish but it's not a good idea to have other appliances on the cooker circuit.
    As you appear to be willing to run two cables unnecessarily for the cooking appliances it would be better to run another for the dishwasher and perhaps other things.
    Without the dishwasher 4mm² cable throughout and 32A MCB will be satisfactory.
    This is allowed for cookers because of 'diversity' as not all the elements are on at the same time.
    Which junction box?
    There doesn't need to be one.
    Not a good idea. Can you not connect it to the socket circuit?
  4. JohnW2
    JohnW2
    28 Jan 2011
    45,560
    Thanks Received:
    2,905
    Buckinghamshire
    Country:
    Are you saying that because it's in a kitchen? If so, and on the assumption that the OP is in England (not Wales), then not only are you not up-to-date with the regulations but you have also failed to read wiki article to which you have linked.
    Kind Regards, John
  5. Johnday
    Johnday
    22 Aug 2013
    10
    Thanks Received:
    Essex
    Country:
    The junction box is so I can split the supply and run it to 2 independent outlets. The oven is on one wall and the hob is going to be on another.
    If I could easily get onto the existing 32 amp ring main I would.
  6. EFLImpudence
    EFLImpudence
    7 Jul 2010
    35,089
    Thanks Received:
    3,895
    Retired to:
    Country:
    Portugal
    The original post is very old, John.
  7. EFLImpudence
    EFLImpudence
    7 Jul 2010
    35,089
    Thanks Received:
    3,895
    Retired to:
    Country:
    Portugal
    You did not say that but still don't need a junction box.
    You did not say that, either.
    I apologise for advising how to do it properly.
  8. Johnday
    Johnday
    22 Aug 2013
    10
    Thanks Received:
    Essex
    Country:
    Thank you should I start a new thred?
  9. Johnday
    Johnday
    22 Aug 2013
    10
    Thanks Received:
    Essex
    Country:
    Dear Moderator 9 sorry for "Hijacking" the thread. But as the thread was so old and my question seemed relevant to it and as this is my first go, please accept my apology .
    John
  10. Sponsored Links
  11. JohnW2
    JohnW2
    28 Jan 2011
    45,560
    Thanks Received:
    2,905
    Buckinghamshire
    Country:
    Damnit :oops:
    Kind Regards, John
  12. Johnday
    Johnday
    22 Aug 2013
    10
    Thanks Received:
    Essex
    Country:
    High praise indeed.
  13. riveralt
    riveralt
    4 Jan 2004
    4,020
    Thanks Received:
    597
    Country:
    You need something like this:
    http://www.alertelectrical.com/prod/1022/click-45a-easyfit-dual-appliance-outlet-plate-prw217
    I'm sure there is a recommended limit of 2 metres from the cook control unit to the appliance though.
    Don't forget that your circuit will need to be RCD protected.
    Also as this is a new circuit you will need to notify your Local Authority Building Control and pay their fee before you start the work.
  14. Johnday
    Johnday
    22 Aug 2013
    10
    Thanks Received:
    Essex
    Country:
    How do I split without a junction box?
  15. Johnday
    Johnday
    22 Aug 2013
    10
    Thanks Received:
    Essex
    Country:
    I fear I have confused you. The cooker and the hob are in 2 completely different parts of the kitchen and need to be run from their own independent outlets. That is why I want to split the feed from a junction box to them.
  16. riveralt
    riveralt
    4 Jan 2004
    4,020
    Thanks Received:
    597
    Country:
    The item I have pointed you to is a junction box.
    Do you have answers to the other questions/points I and TTC raised on the duplicate post?
    Like - have you notified Building Control?
    Is your circuit RCD protected?
    Why do need a 45A MCB - diversity?
    etc etc.
    There may be a big bas wolf along later who will point you in the right direction - for once I agree with his comments before he makes them.
  17. JohnW2
    JohnW2
    28 Jan 2011
    45,560
    Thanks Received:
    2,905
    Buckinghamshire
    Country:
    I'm inclined to agree, but I would never be brave enough to agree with his comments before he makes them - since they have been known to be such (at least in terms of how they say it, rather than what they say) that I wouldn't want to be in any way associated with them :)
    Kind Regards, John
Loading...
Share This Page
