Hi
I have an old Ideal W CF460 boiler that works perfectly, but has outlived the old mechanical programmer that fits inside the boiler casing
I've been in touch with Ideal and they say the programmer is discontinued and that I'll need to fit an external replacement
The system is a traditional pumped heating with gravity hot water (cylinder directly above the boiler so works OK). We don't need/want anything too technical and fancy, just a simple type that turns the boiler on/off twice a day with an override facility to turn it on/off manually is all we need.
Can anyone recommend an easy to fit, easy to use and reliable replacement programmer please?
Cheers
Bob
Cheers
Bob
