Hi folks,
I installed a replacement electric shower which is fed from the cold water mains.
However, it works but the water is cold unless I turn up the temperature gauge almost to the top when in low/med and high settings.
To be honest, I have played about with the different valves trying to figure out what to turn off etc.
I have read that if the pressure is too high/low, the temperature can be effected but have not read about th temperate being cold and with a slight change in temperate control suddenly getting too hot.
Any ideas?
Any ideas?
