I have a Worcestershire 24i junior boiler. The water is boiling hot coming out of the taps, but when using the shower it goes cold.
I’ll turn the shower on get it to the right temperature then after about 2 minutes it goes cold and to get the shower hot again I have to run the bathroom sink tap and it will come back up to temperature but when I turn the tap off the shower will go cold again.
I have been told that my water temperature is too high so when it’s mixing with the cold water I’m not using enough hot water so the boiler cuts out but I don’t know how to turn the water temperature down. Is this correct? Any suggestions as how to fix? I’m in a rented property and it’s been like this since I’ve moved in about 2 weeks ago I’ve turned down the only dial on the boiler but it hasn’t made any difference.
