Replacing 3 port valve advice on drain down isolation
16 Nov 2026
Hi all,
replacing 3 port valve on central heating system, seems straightforward but my concern is with hot water storage tank.
Can I work on the 3 port valve by just bunging the cold-water-storage tank in loft?
Or do I need to isolate/ drain down the hot water tank?
My question comes from seeing the 3 port valve pipework to the hot water tank, what's to stop it coming out when disconnecting the 3 port valve body?
like to check before carrying out job, if I need to drain down system.
bit of detail:
Cws tank in loft.
Drayton ma1 and green hot water tank on first floor.
Boiler worcester bosch greenstar ri on ground floor.
With a bit of learning I was able to replace the actuator head last year, and now need to replace the mechanical valve body as there is a weep/ slow-leak from the spindle.
I've attached pics to show system.
I can see the feed pipe underneath the valve and the two pipes flowing out of the valve, one for heating, one for water.
deciding whether to order a bung kit for the cws header tank. I understand there is a bung kit 'Regin radvalve change kit' for the tank in loft.
Anything else I've missed?
Of course if not possible to do without draining down system, I'm happy to do it. there's a hose pipe fitting on ground floor rads. I understand only needs to be partially drained to first floor 3 port valve but not sure how to know when enough without checking directly (shall prepare a container or two under the valve just in case)
I've got adjustable wrench, do I need any special tools?
shop list: drayton 27101, bung kit, ptfe tape, plumbers paste.
Many thanks
Thanks, I had quick look at loft water tank, presume it's the smaller tank (closest, open top with ball-cock).
Circled blue - presume that's the feed to bung,
Circled orange - presume that's the vent pipe to bung
