Replacing 640mm wide radiator with a 600mm – Can I bridge the gap with extension tails?
29 Aug 2020
Hi everyone,
I'm looking to replace an existing double radiator that measures 640mm wide.
Because of sizing options and availability, I'm considering replacing it with a standard 600mm wide double radiator. That leaves a 40mm overall gap difference (20mm on each side) between the new radiator and the existing floor-entry copper pipework.
My main goal is to avoid draining down the system and altering the rigid copper pipes underneath if possible.
I've seen radiator extension tails (also called valve extensions / rigid extensions) mentioned as a potential solution, but I've never used them before. A few quick questions for anyone with experience:
1. Will extension tails work here? Since the new radiator is 20mm narrower on each side, will adding a 20mm (or adjustable) rigid valve tail extension to each side allow me to connect straight to my existing valves without moving the pipework?
2. Types of tails: What type of extension tails are best for a 20mm gap on each side—fixed length, telescopic / adjustable, or rigid male-to-female adapters?
3. Sealing: What's the best way to seal the threads into the radiator tapping (PTFE tape, thread sealant/Loctite, or rubber O-ring fittings) to ensure no slow leaks behind the valves?
Any advice on whether this is a straightforward DIY fix using tails would be greatly appreciated!
Thanks in advance!
Yes, normally, if the existing valve takes a 15mm tail. A photo would confirm.
Get fixed, if too long you can cut them.
Loctite 55, but expensive for one radiator. PTFE would do just fine.
