Hello everyone, from a complete newcomer to this Forum. This is my very first post, so I'd appreciate it if you could bear with me.
I need to replace the 3-way valve, positioned below my hot water cylinder, which switches the flow between central heating and hot water.
I have purchased a valve identical to the existing, and have a reasonable idea of the sequence of events which I need to carry out, but would feel reassured if someone with "the knowledge" would verify that I am on the right track...
1 - tie up the ballcock in the main tank (or the f&e tank) in the loft
2 - connect a length of hosepipe to the drain valve on the lowest positioned rad, and open the drain valve.
3 - open 2 or 3 bleed valves on the upstairs rads, to allow the system to drain. Is there a valve on the hot water cylinder?
4 - how do I kow when the system is sufficiently drained, other than by starting to undo the connection on the old 3 way valve?
5 - remove the old 3 way valve, and fit the new one (do I use boss white, ptfe, or?), together with the controller unit on top of it.
6 - shut off the drain valve, and any open bleed valves.
7 - add some (how much?) inhibitor (fernox?) to the tank in the attic, and untie the ballcock, to allow the system to re-fill.
8 - bleed all rads (start downstairs, or doesn't it matter?)
9 - fire up the boiler, and check that the switching works correctly.
10 - job done?
Any advice would be greatly appreciated.
Thanks, in advance.
OJ.
10 - job done?
Thanks, in advance.
OJ.
