Hi All, I'll try not to make this too longwinded, our Kitchen is in a cellar and has allways been a damp place, the present extractor fan in the kitchen is vented directly out of an external wall which vents externally about 250mm above ground level. this fan is now broken and we would like to replace it with a humidistat type extractor fan. the present fans power is fed via the ring main from the floor above and comes down to a switched fuse then on to the extractor, we operate the fan via the switched fuse, all cables to and from the fan are in the walls, any suggestions as to the simplest to wire a new humidistat fan, Ican probably manage to feed a new cable from the fused switch to the fan via the existing conduit, would it then be possible to buy a three pole switched fuse? open to any ideas
thanks John
thanks John
