Replacing boiler with a new Baxi 424 in ground floor flat
10 Feb 2017
Newport Wales
Hi
I've decided to replace my old Worcester 24cdi with a new Baxi 424
It will be sited in place old CDI .
the existing flue will obviously be replaced with a new item and will terminate through side wall of building.
The centre of the terminal will be 1.820 metres from ground level.
Is there a min height that the terminal must be before a guard is required?
There are no windows or openings within a metre.
There isn't a walkway alongside the outside wall.
Do i need to consider anything else, before i start ordering parts?
Iirc it’s 2m, used to be 2.1 and it’s nothing to do with pedestrians, so yes, you would need a guard.
Thanks for that Countryfan
What does lirc stand for? ( only interested)
Cheers
If I remember/recall correctly.
Edit: This is from the 424 Installation manual
