Replacing Danfoss with Honeywell 2-port valve
10 Dec 2008
Jersey Marine
I have a Danfoss 2-port valve model HPA2 (which has suspect motor issue)
I can get Honeywell 2-port valves & motors much cheaper & easier as local Trade place stocks Honeywell.
Is there a direct equivalent Honeywell motor activator? ....... so I could just swap the synchronous motor over ? or would I need to swap the whole valve ?
Trade counter said there is also a generic synchronous motor that fits either ? .... they any good ?
Ideally, I would obtain Honeywell complete valve, but just swap over the motor now ..... and change valve later when the system can be drained down.
All valves use the same motor, but only use a SYNCHRON motor under £20 if it is labelled Synchronious motor it is a cheap Chinese import
