my current 8Kw shower has stopped working. I was looking to replace it with a 9.5Kw shower. The cable back to the CU is 10mm the MCB is 40A (in a Crabtree RCD CU). Would i be advised to increase the MCB to a 50A for the shower?
If so are they easy enough to replace? the fuses are Starbreakers with the spade connector on them.
The main Electricty board fuse is rated at 80A.
Regards
Jeff
Regards
Jeff
