I want to replace a cm907 thermostat with a 927 and bdr91 relay. Removed 907 stat from wall to then wire in the bdr 91. 907 has only two wires - brown (live) to A and grey (neutral) to B. There is also an earth and a fourth black wire which are not connected. Bdr91 seems to requires L and N feed as well as A and B. Have had a few attempts based on wiring diagrams supplied and can get the relay to communicate with the wirelss stat but relay doesnt then communicate with boiler. Boiler is glowworm flexicom 24hx. Can anyone tell me how to wire this correctly? Thanks
