Greetings All,
Just after moving in to our new home i started replacing the old lights with LED's unfortunately I bought MR16's instead of 11's but they will fit into the wiring (if not the fittings exactly). I tried one or two at first but have now plugged them all in and everything seems ok. I have seen the transformer under the floorboards but can't remember its range now, however there wasn't any flickering. Well not straight away, after about 10mins or so some flickering did start but then it seems to come and go. I guess I will likely have to replace the transformers..although access is not easy. That aside from that are there any other issues with me leaving the set-up as it is (assuming flickering is transient/controllable) ?
Cheers...Chris
Cheers...Chris
