Replacing radiator after decoration
15 Dec 2007
Yorkshire
Is this the right procedure When i replace the Rad I turn on just one side and fill the rad at the same time undo the bleed valve until all air is dispelled then turn on the other side After this re pressure the sealed combi system thanks
Every day is a school day ...i always just opened both valves..you could well be right
just open both (with the heating and water switched off as you fill the radiator)
