Morning,
I have a Thomas Dudley Niagara Pneumatic Dual Flush toilet. I've been having issues with basically it only flushing if I hold in the push button. I got a plumber out for another issue (the pan connector had come away from the wall) and asked he look at the flush as well. He decided it was the flush valve and changed it to see if that fixed it but it didn't as the valve was working fine and properly. He checked the water inlet and all fine. Sometimes the toilet would actually just run for ages so he'd turn it off at the isolater valve.
He said it seemed like my push button was faulty as it wasn't able to push enough air to get a flush or something. There's no leaks in the tubes and he switched them around onto the dual flush button and the same issue happened where you have to hold it in. The button feels really weak when you push it - like there's no pressure behind it and if I want a full flush I have to press it in quickly and hard in the hopes it sort of catches and does the flush properly.
I'm living with my parents and they said they couldn't be bothered to spend more money and said to just keep using it by holding the push button in. However - it feels less and less effective. This problem is over a year old now and it hasn't actually stopped working so I understand what they're saying.
How easy is it to change myself? I'm fairly sure it's this I need - Dudley Vantage 51mm Dio Pneumatic Dual Flush Push Button 327733 - that I can order myself. It's just connected to a horizontal plinth that I know how to pull out and I know where the tubes go to connect it. I'm a female with zero plumbing skills so happy for someone to tell me it needs a professional or if there's any really indepth youtube vids I can watch.
