Hi all.
I have two inspection chambers and between the two (Approx 5Mtrs) a tree root seems to have broken in causing a blockage every 4-6Mths.
As I fear this is likely to get worse, not better, my plan is to replace ALL of the pipework between the two chambers with one continuous length.
And, being lazy (Old) I am paying someone else to dig out the soil.
I expect that I should be able to remove old pipework and dig about 4 ins below and lay some gravel, knock out the cement from inspection covers and feed new pipe in having first cut end off at an angle (approx 45Deg?)
I am planning on mortaring in the two ends using quick drying cement.
Does this sound about right?
Any advice before I start?
