Hi all moved into my house around 2 years ago and have come to notice at the back of the house we have a section of wall where quite a bit of the motar has come out of the walls.
It seems whoever lived here before thought it would be a good idea to shove bits of old wood into the gaps rather than sort the problem out properly (not the only bodge job I've found!). I'm guessing its just a case of removing the wood and re-filling the holes back up and using a brick jointer to get the required finish?
As you can probably tell I'm no brickie and only started getting involved with DIY when we moved in and found all things were not rosy! Is it a task a DIYer can take on and if so what mix would I need to make sure I fix the problem properly?
I may also have to replace a couple of bricks as the face of them has crumbled off, probably due to water getting in the gaps and freezing and thawing?
Cheers
Cheers
