Restarting Perrymatic boiler after running out of oil
31 Jan 2008
Sussex
Perrymatic Jetstream Mk 2 boiler with Mectron 3BM pressure jet burner. Oil was delivered earlier today. I tried the restart button several times and the the boiler sounded as if it was firing on two occasions but there is no joy now. ANy suggestions
sounds like rubbish has blocked the filters
Unjustified conclusion unless you've looked.
Turn off oil, disconnect pipe at pump, put end in pot, turn on oil. Will push air out and if it doesn't then filter probably blocked.
Reverse operations and turn on power. Check for oil leaks.
