Restricted access felt roof condensation
27 Nov 2025
Old felt roof has corrugated metal overlay so sealed all round. Condensation forming on underside drips on old felt which leaks a bit. I need to gain access through holes either end and spray loads of pour-on (very liquid) sealer so it floods the surface and hopefully finds the cracks. So I need a sprayer with a reasonably long shaft to poke in and let rip. Any sealer and sprayer combinations out there to do this? PS option to remove any part of the corrugated structure not possible. Thanks.
The solution I have come up with is to cut out long slots between the joists inside (removing the ply overboards. There is enough room to spread out Bostik liquid Bituminous mastic plus if necessary I will remove more of the board between the other joists and staple up some drip barrier on the battens on which the corrugated roof is screwed. As I said removing the metal roof is not an option. it's only a condensation problem, the roof itself does not leak and there is no ingress even under storm conditions. A summer job I think.
