Reverse Thread Drywall Screws
11 Feb 2009
London
Hi, I am about to fix 12.5mm Knauf Soundboard plasterboard to C24 50x100mm studding, for a bathroom.
I read about this item (Reverse Thread Drywall screws):
http://www.screwfix.com/p/easydrive-black-reverse-thread-drywall-35mm-pk1000/39263?_requestid=316224
So far I have been using these to fix to timber (Twin Thread Drywall):
http://www.screwfix.com/p/phosphate...5-x-38mm-pack-of-1000/12984?_requestid=316578
Are the Reverse Drywall Screws a luxury or necessity, especially around a door opening.
Thanks[/url]
The reverse threaded part is just under the head of the screw and the idea is that it helps to countersink the screw heads. I think the idea may work better when fixing timber but I an unconvinced of any additional advantages it brings to plasterboarding as I find the normal threads are fine.
Thanks, I am concerned Normal Twin Thread Screws might work loose over time with a door banging open and close, as its timber I'm fixing too.
I believed the normal Twin Thread Drywall screws are designed to screw into the metal studding ?
