Riello pump pressure test
22 Feb 2006
I want to check the pressure on a Grant Vortex Riello burner, but can't find any info on residual pressure; eg if I remove the test-point Allen screw, will it spit out 8 bar of kerosene all over the utility room, or does it only work up to that pressure when running?
Thank you!
With the greatest respect, asking a question such as this does suggest you should not be messing with your burner.
Agreed, but skilled tradesfolk in remoteland are impossible to source, so I have to learn new skills - even if I don't want to!
What model burner do you have? The pressure port usually used is the conveniently placed lower hexagon screw below the pressure adjuster.
What problems do you actually have?
