- Joined
- 10 Nov 2003
- Messages
- 5
- Reaction score
- 0
- Country
I have just moved in and I have a new consumer unit with RCD etc however older wiring I suspect. It looks as if the consumer unit was fitted to have an electric shower which is the only other modern thing in the house.
I have one breaker that says sockets and one that says lights. When switching either off , I naturally lose power to the whole house sockets or lights.
Ideally I would put in another ring main for upstairs sockets. Currently I have about 12 double sockets around the house about 3 I am guessing are spurs because of the proximity. I have concrete floors and it doesn't look likely , but if its not much hassle and I can find a way of routing it I will do it.
I have now added an extension onto the house and someone knocked down what was there already and taped up the wire ends and left them sticking out of the wall. I cant actually remember what was there originally , but seem to remember a fluorescent strip light and and washing machine in there when I looked around. This makes me think that there was both lighting and socket power there. However...
Now the structure is built , I have looked at the wiring and there are just two wires of the same dia sticking out of the wall. it looks like 2.5 mm cable.
What does anyone think I may have here?
My thought is that perhaps this is either end of a ring main? and that the strip light may have been on a fused spur?
It doesn't appear possible to get to the lighting circuit in the next room , without ripping up expensive flooring.
My electric is still functioning however, so have I now got two radial circuits?
Baring in mind I would want 4 double sockets in the extension and three separately switched lights, what would it be best for me to do.?
If I have two ends of a ring main, should I :-
a) Extend the ring to cover the extension sockets and spur off three fused boxes for the lighting circuits.
b) Not join the ring (if thats what it is) and extend both of them to cover some new sockets each and some fused spur lighting so having two radial.
c) It may be possible to branch each end back to the fuse box so creating two rings. Is this easy?
d) or some other combination.
Can I run three lighting spurs off of three different sockets in the absence of a lighting circuit?
How to I check what I have (ring or radial)?
anyone's help would be appreciated.
