Hi got a RM stainless steel vented direct cylinder 450x815 about a year old.
Want to fit a 1.5bar shower pump to boost the hot as fairly poor.
As it’s SS the connections are welded 22mm so unable to get a Surrey flange for pump. I noticed there is a capped outlet on side near the top of cylinder guessing a secondary return. Would I be able to use this for the shower pump feed? Also wanted to boost all the hot taps bath/basin and sink. So could I cap the hot outlet of top of the cylinder draw off after the vent obviously! And pipe it from the pump outlet back into the hot water pipe if that makes sense?!
thanks
thanks
