- Joined
- 24 Nov 2020
- Messages
- 7
- Reaction score
- 0
- Country
Hello all, I am new here so hoping this is in the right place. I'm looking for some advice regarding timber sizing for a roof:
I plan to build a room on top of an existing attached garage. The overall dimensions will be 5.5m wide x 8m long (brick and block with 50mm cavity). The room will be open with no internal walls.
The roof pitch will be 30 degrees to match the original house. The plan was to use 4x2 rafters and ceiling joists (which will be ~8m long) with binders and purlins running from gable wall to gable wall. However, using the TRADA span tables I can't find a purlin size that will span 5m (e.g. from inner skin to inner skin). Question is: Is there a purlin size that can span 5.2m and if not, what could I support the purlin on to break the span, given that there are no internal or load bearing walls that a strut would sit on?
Thanks for the help,
Robert.
Robert.
