Roof framing - Advice needed on what fixings to use?
4 Feb 2010
Hertfordshire
Hello Oh Knowledgeable ones
I have got a question relating to what fixings to use when framing a roof.
In a ‘normal’ simple roof that consists of joists, purlins, wall plates and rafters what fixings are used at each position?
In my extension, where I have fitted floor joists on Jiffy hangers, the hangers have about 20 of the twist nails holding them to the ledger board, and then 4 (2 each side) into the joists.
For the roof though, I need some advice. I have got the BCO coming round on Friday to discuss it, but like always, I would like to be armed with info from you guys, so that I am prepared for the conversation.
I have managed to borrow a Paslode Framing Nailer from my father in law, (awesome piece of kit) and those ribbed nails are rock solid once they are fired in.
These are the fixing points that I am not sure about…..
1. Fixing the wall plates to the wall – Do I bed them on mortar? And/or screw them into the blocks?
2. Rafters to Wall plates – Do I fire nails in at about 45°? What length nails and how many?
3. Joists to rafters – I am assuming - M12 stud all the way through, and one of those sharp toothed connector washers between the pieces of timber.
4. Joists to wall plates – Same as Rafters ?
5. Rafters to purlins – are they attached, or do the rafters just rest on them?
6. Rafters to ridge – Nails ?
Cheers
Gary
With a nailer, you'd use 90mm nails for all of it and two per fixing
And straps about 1-1.5m for the wallplate
Simple as that !
Sounds good to me, and plenty of opportunity to use the nailer !
And I bet you with the paslode in your hand , you will use more than two nails in every joint....
Fire away..... :)
Fire away
If only...
Paslodes are rubbish. Have one and its give nothing but trouble misfiring.
Left it in to a paslode approved repair center, parted with £45 quid and still misfires.
Fire away
If only...
LIttle boys and their toys....
Looked after, and respected, they are superb.....
There again... They must be used more than twice a year....
Was using mine every week. Shuttering framing. Have it about a year now.
What bugs me is it was left in to get fixed/serviced and its no better.
Cannot understand... the only time they mis fire is with old gas or abused...
Well luckily for me, the Paslode I have got is borrowed, so if it goes wrong I'll just give it back ! ! !
Seriously though, I have borrowed it on a few occasions and have always found it to be brilliant. Never missed a beat.
