    Dismiss Notice
Roof insulation
Discussion in 'Roofing and Guttering' started by chrisfsi, 27 Nov 2010.
  1. chrisfsi
    chrisfsi
    14 Jun 2010
    18
    Thanks Received:
    Sussex
    Country:
    I'm refurbishing a single skin brick shed for use as a hobby room / pottery. As the winter approaches I'd like to insulate the roof a bit. At the moment it's tile hung with no felt or lining paper - see pictures. I know the ideal would be to take off the entire roof and replace but I'd like to avoid that if possible!
    [​IMG]
    [​IMG]
    My current thoughts are to wedge strips of Kingspan / Celotex between the rafters and cover the whole lot with hardboard or 9mm plasterboard. I'm a bit concerned about the plasterboard as that will be quite heavy. Any view or comments on this? Very grateful for alternative suggestions or approaches?
    Assuming this is a good way to go, I assume I need to leave a vapour gap between the top of the Celotex and the underside of the tiles. Do I also need to leave a gap at the apex and the eaves or can I fill in right up to the ridge and head plates?
    All advice welcome...
    Chris
  2. smashngrab
    smashngrab
    9 Oct 2009
    117
    Thanks Received:
    7
    Bristol
    Country:
    You could use that stuff that comes in a roll,its like a tinfoil sandwich with insulation as the filling.you can tack it up using a staple gun.Then tape the joints up to keep the drafts out,not to much weight to worry about.
  3. Sponsored Links
  4. chrisfsi
    chrisfsi
    14 Jun 2010
    18
    Thanks Received:
    Sussex
    Country:
    Oddly enough thats what I had up before when it wa just being used as a shed, and I must say it seemed to make no difference to the temperature whatsoever :(
    Wouldn't the Celotex/Kingspan option would be much more effective?
    Thx
  5. smashngrab
    smashngrab
    9 Oct 2009
    117
    Thanks Received:
    7
    Bristol
    Country:
    How about a flase ceiling,at least you wouldn't be heating up all that space
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
