ok, although I've posted some of this on another topic, this question better clarifies my query.
I have a 18 degree lean to roof on my extension which I am struggling to complete due to the ventilation requirements.
The construction at present consists of 7 inch joists from pitching plate to wall plate on internal wall. There will be 3 velux windows in the vaulted ceiling as well.
I had planned the following.
Install 100mm celotex in between joists, leave a 50mm air gap above, then put down tyvek supro membrane (tight or sagging?), battens, then tiles. BC also requested I put 30mm celotex on the inside of the room joists to insulate them.
After speaking to sandtoft who make the tiles, they have stated I can either vent the roof, with their very very expensive eaves and top abutment systems, or I can completely seal the roof. After visiting the roofers merchants today and getting some more advice, they said they hardly ever sell these venting systems.
So really I just need to know how to put this roof together. The joists are down, I have the insulation, battens, membrane and tiles ready to fit, but I cant start until I work out this ventilation problem, and whether I actually need to do this. My house has no facia or soffet boards on it. I believe the roof is a ‘warm’ roof. I also dont have any tolerance in place to fit counterbattens due to position of windows above the roof.
I have read numerous documents from Sandtoft, Tyvek, Clay roofing association etc. all seem to contradict each other.
Thanks in advance for any help.
