I have a single skin brick shed that I'm planning to convert into a liveable room. The roof is flat 18mm ply on top of ceiling joists. Felt covering. How should I go about insulating the ceiling? If I could lay the insulation sheets on top of the joists I understand this would qualify as a warm roof. However that is not possible for me. I could fix the insulation sheets to the underside of the ceiling joists or I could fit the insulation between the joists or I could do both - fitting insulation between and to the underside of the joists. This would make it a cold roof would it not? Are there any ventilation requirements to consider? I have a uPVC fascia but no soffit. It has been suggested to me that I should fit Celotex insulation boards to the underside of the ceiling joists and install vents into the front and rear fascia board to allow free air to pass between each of the ceiling joists. Is this correct?
