I'm considering converting an existing garage/utility into living space and am unsure on the best way of insulating the existing cold flat roof. The joists are 8" deep and it's currently ventilated via the open cavity. Should I either:-
a) completely fill the void between the joists with insulation with rockwool or kingspan and seal the cavity?
b) partially fill the void with insulation leaving a ventilation gap, if so how thick should the rockwool or Kingspan be?
c) apply kingspan insulation to the underside of the existing garage ceiling, and how thick would it need to be to comply with the regs?
I'm reluctant to apply insulation to the underside of the ceiling as it would reduce overall room height (it's already 150mm lower than the adjacent rooms).
Your thought/guidance would be appreciated.
Andrew
Andrew
