Room Stat
27 Nov 2008
Norwich
Hi All, Im new to all this but just need to clarify something..
I have a Satchwell TLX 2356 room thermostat which has sadly died - it doesnt allways turn the stat on when it should.
Anyway I have bought a new stat a Sunvic TLX 7501 Digital stat which I belive will do the same job.
Question I have is that unlike the old unit there is no earth connection on this unit. The new stat has the double insulated marking so do I just leave the earth unconnected and tape it up?
If it makes any difference this is to control a fully pumped 'S' type system.
Many Thanks, Chris.
Yes you are correct. If there is no terminal to attach the earth to (working or not) then just make safe as you say.
No problems for your 'S' plan.
Thanks Dave, So if I just tape up or terminate in a block I can then put this back in the wall behind the stat and all will be fine?
If there is a box in the wall behind the stat with an earth terminal screw in, then connect it to that. If not, put the earth cable into one segment of chocolate block, tape it up and tuck it out of the way. You are using a double insulated component that does not require an earth. No probs!
