My central heating system is managed through a Honeywell Sundial Plan Wiring Centre terminal box and Honeywell T6360B Room Stat. The room stat merely acts as an on-off switch in that it is only Live in and Switched live out - wired to terminals 1 and 3 in the term box (room stat). In order for the T6360B to operate correctly it presumably needs a neutral wire. Is terminal 2 in the term box (room stat) the neutral terminal that I should use for this purpose.
