room stat
7 Nov 2005
Staffordshire
Have Y plan,boiler glowworm hxi condensing,room stat honeywell T6060B, program randall 4033. Just replaced 3 port valve.Working ok, on both water and CH and both together. However unable to stop heating by room stat or switching programmer off, have to stop with isolating switch. tried other stat still the same.When switched back on have to turn up stat to start heating as normal. Wiring problem ?
I have not fully considered the logic but I am wondering if you have connected the motor valve correctly.
Does the "A" port go to the heating or the hot water ???
Tony
