Hello,
I've moved a four wire room thermostat and it now seems to override the controller for the system. That is to say that if the room thermostat is calling for heat then the heat comes on regardless of whether the Central Heating is on at the controller or not.
The Thermostat is a four wire version with Red, Blue, Yellow and Earth wires with ACL marked on it. There is an 'LWC1 Wiring Centre Wiring Guide' available.
It includes guides for various systems, but I don't know which type of system we have. The options on the wiring guide are as follows:
'C-Plan Type Systems, Valve on Gravity HW Return.
'Mid-Position Spring Return Valve Systems (Biflo, Y-Plan, etc.)'
'Spring Return 2-Valve Systems 22mm. (Twinzone, S-Plan, etc.)'
All of these three plans call for the Room Thermostat to be wired as follows:
Wire 1 (Com) in Thermostat -> 3 in Wiring Centre
Wire 2 (Call) in Thermostat -> 2 in Wiring Centre
Earth -> Earth
Wire 4 (Neutral) in Thermostat -> Neutral in Wiring Centre
View media item 78188
The image appears upside down, I'm not sure how to reverse it for here.
Can you help me wire this in correctly?
Many Thanks,
David
Earth -> Earth
Many Thanks,
David
