Sounds to me like he was rubbish! No inhibitor and no room stat. There`s a wireless 7 day programmer and room stat for these, plugs in the boiler. Worcester MT20.
Thank you i do have a programer put in the boiler will i need to change this to use the room thermostat you mention, yes he was rubbish but its too late now i have paid him i am just trying to sort the system out, have tried to get other plumbers to look at but they are all too busy and i need it done fairly quickly which is why i am trying to get your guys expert opinions many thanks
Yes you`ll need to take out the existing timer. They`re a staight plug in affair. Not cheap, about 120 to 150 quid, but saves on wiring etc, and you can do it yourself. And yes, the room with the new room stat in should have the trv removed.
Thanks will i also need to flush the system before adding the inhibitor he left for me to put in or can i just drain it and put in the inhibitor, sorry to ask what is probably obvious but i am no plumber thank you.
Buy some sentinel X300, put it in the system, read the bottle, follow the instructions, flush thoroughly, then add the inhibitor, preferably a good brand name such as sentinel X100. How on earth did your plumber fill in the benchmark if he didn`t even put the inhibitor in?
Thanks will do as you suggest the plumber took the benchmark to fill in and never returned it cant say i am happy about it but seems little i can do now, have tried to find a local plumber using this sites find an expert but none are listed in my area, so i have to try and sort it out myself many thanks for your help.
