I'm in the middle of doing the kitchen.. nothing in there but a shell..
at present, the gas pipe to my gas hob will go round 2 walls of my kitchen and round a chimney breast..
it's not connected as the plumber capped it a short distance from the meter ( in the corner of the room ) and ran the other side to where the gas hob will be.. he'll come and connect up once the wall has been plastered hence why it's in 2 parts..
on the wall the gas hob is going on, i have studded it out to allow for electrics and radiator pipes to be hidden.. ( effectively boxed in an entire wall.. )
above the gas meter is the boiler and the rad pipes go up the side of it into the loft (second storey flat.. loft is mine.. ).
I'm going to be boxing in this wall as well.
rather than having the gas pipe exposed, i'd like to run it up the wall with the heating pipes and across the loft to the other wall and down vertically from there....
1. is this allowed as it's not outside and the roof is ventilated.?
2. can i do the pipework myself but just leave the final connection to the corgi guy? ( both ends..)
3. what's the best way to terminate the gas line out from the stud wall for connection to the hob?
