Ive spent some time learning about the formula and calculations required for fitting a UB to partially replace a supporting wall. I have done the brain work and calculated what I'll need, beam size, block column size and materials and foundation etc.
However my research has not been able to answer some basic questions re the construction. Can anyone help
Is it acceptable for the beam to just be restrained laterally by the perendicular floor joists it will be in contact with or should the beam be attached to the joists i some way?
Should the ends of the beam be bolted in some way to padstone below it and attached in some way to the blockwork at its end face or is friction between the surfaces sufficient?
What is your padstone preference? Im thinking casting in place would be easier as the beam can be jacked up tight against the joists and the concrete poured right to the bottom of the beam.
If I use eng brick whats a good technique for getting the beam to fit tight between joists and the brick padstone. I understand packing is often used but this seems a bit of a bodge to me especially having gone to the trouble of construcing a nice brick surface for the beam to sit on
cheers
Ian
cheers
Ian
