I'm a little concerned with my SE's beam calcs.
We at building a 5m wide extension, at the back / end there is to be a full width & height bi folds.
The floor / ceiling is to be continuous, my SE has designed two C section beams bolted every 600mm, now each beam (bolted together) are bearing on 100 mm engineering brick either end but as this is over doors they are not restrained on each face ( one face is external )
It is a two story extension the floor joists are not transferred to the steel but the end upstairs wall and barn roof will be.
The "designed" beams are 240 * 90 * 32kg
I thought these seemed small - expensive enough of corse!
Cheers
Martyy
Cheers
Martyy
