Running AC On Solar Panels
13 Sep 2010
Wrong side of The Channel
Been looking at some smallish 2 and 3 bed houses in Portugal. Would probably need AC for the summer months. If I had AC fitted and added solar panels, is it likely the panels will produce enough to cool the house during daylight? I realise it's a bit vague as I don't have exact dimensions. Thanks in advance for any advice.
I can't see that working. I think you'd need inverter and battery bank to make this work reliably.
What wattage is the AC (roughly)?
Might give you a few ideas browsing here:
Off grid set-up
According to Google, "On average, a central AC system uses 3,000 to 4,000 W."
Without a battery bank you would have to design for a solar setup able to provide that output under less than optimum solar conditions during the day, so I'd guess around 6kW rated output. But wouldn't you want the AC on at night too?
Thanks to both for your replies.
Mr Chibs - No wattage as it's a hypothetical question as not bought anywhere yet. Just to see if it was feasible with average panels on an average AC system for a 2 or 3 bed house.
Alec_t - Yes, AC on at night, but more than likely that will be powered by mains electricity. Maybe getting the house as cool as possible during the day on solar may help to lessen energy use at night. Though this maybe wishful thinking.
There are two methods, stop the heat getting in, or absorb the heat which gets in, thick walls can help, I know in the 80's when I lived in Algeria we tried all sorts with our workshop, the accommodation had AC's but not our workshop, bricks to allow an air gap, and tin sheets helped, best was to try and grow grass on the roof, until some one worked out how much water we were using.
But as we move to warmer countries there is a tendency to use flat roofs with access, so solar panels can be maintained, and the peppers dried out. (That was Turkey) In the main there was not much free space on the roof, solar panels heated the domestic hot water.
But what is more important is what are the Spanish rules? They seem to have a different method of charging for electric, more like our commercial method, here in UK we have 60, 80, or 100 amp supply, and standing charge same for all, but in some countries it is charged on the peak use, it was limited with a fuse, so going over for a short time was OK, but with the advent of "Smart Meters" going over for a very short time can either get fines or disconnection.
I know this happens in France, not sure about Spain, so a UK forum is really not the place to ask, as there system is so different, here we do have split phase supplies to remote farms, but not village homes, but it is common in other countries, we see imported cooker hobs designed for split phase.
