Im running a new supply pipe about 150m from the meter to my house. The first few meter's INTO the house was replaced in 25mm MDPE a few years ago.
I'm going to run 32mm MDPE the whole way and will need to connect it to the 25mm using either a standard reducer (32-25) or if I can find it, a reducer with built-in stopcock so i've got a stop cock nearer the house.
The first 30 or so metres FROM the meter apparently were replaced many years ago and ill check that when I excavate.
My question is rather than have to get the water board out to connect it all up directly to the meter and inspect the trenching and chlorinate the pipe etc Can I be a bit sneaky and just connect up to the (hopefully existing) 25mm MDPE about a foot from the meter?
I assume going from 25mm to 32mm back to 25mm isn't ideal but at least i'll have good flow most of the route.
Advice please?
Advice please?
