I need to get microbore from the first floor void into the room below. Currently this is run through trunking that has been stuck to the wall and looks awful.
Is it possible to run the microbore through the cavity space in the wall and bring it back through into the room at the bottom of the wall therefore keeping it out of sight?
My main worries are:
1. will the cavity space be large enough to accomodate the pipes (and conduit if nessecary)?
2. Will the pipes be at risk of freezing in the winter? Should they be insulated if they're in the cavity space?
3. Should I run them inside some condiut pipe?
I'll be using 10mm hep20 too if that helps.
Many thanks
Many thanks
