running two rads from one pipe drop
3 Mar 2007
Manchester
Can anyone tell me if you can run two radiators in parallel from one drop of 10 mm pipework, or does it have to be 15mm to do this?
Thanks.
If its already in 10mm then should be ok but as bahco says best in 15 ..
the drop is already in 10mm already as it is an existing system.
I just want to add one radiator onto the system in the conservatory.
I no that 8mm is a no no and 15 is best but if I can get away with it on 10 mm then it's a much smaller job.
Drop another pair of pipes down.
It will have to have it's own controls to comply with regs anyway.
