Hello all,
On one of my radiators when the heating is turned on it makes a noise which sounds like water rushing into the rad.
This radiator has a manual lockshield valve on it.
I tried to solve it by closing the other lockshield slightly as I thought this would restrict the amount of water moving around but this hasn’t sorted it.
My pump is set to the lowest setting as this is enough to heat my house, when I turn this up the noise gets louder.
The noise is loud enough to wake you up in the morning and the only solution so far is either wait it out or knock the heating off.
I should add - the valve itself has been changed as the last one did the same, the bloke who did it basically said if that doesn’t sort it he doesn’t know what will!
Has anyone got any ideas?
Thanks.
Thanks.
