I have what appears to be an S plan system, but the hot water cylinder connections are slightly different to a typical setup. It's an old system so I wondered if there might be a reason for these differences.
The image below shows the valve assembly. The pump output comes vertically down (red arrow), and then there are two motorised valves. The top one is for the cylinder coil and the one near the floor is to the radiators.
The upper two horizontal pipes are for the cylinder coil. The one near the floor is the return (for the whole system)
The cylinder coil seems to be in "parallel" with the boiler flow, causing slow hot water. Is there a reason why it might be installed like this?
Thanks in advance
Thanks in advance
