Hi, Sabre boiler was broken had a Corgi guy came he reset the boiler sealed a small leak in the pressure pipe, then it worked for a day and then stopped. (red light)
I found out that there was a condensation water build up, so when I clear out the water from the Siphon (No. 10027546) it works for a day or two, until the water is filled up again.
Do you think the problem will be fixed buy buying a new "Condensation Pressure Switch" (no. 10027535 ), this is the pressure switch that have a rubber tube that links directly to the condensation Siphon.
