Recently my Sabre HE boiler has been firing up as normal. However when hot water tap is switched on the boiler seems to fire up then cut out seconds later, then firing up again seconds later repeatedly. This is causing issues when trying to have a shower, run a bath or run hot water to wash up with consistently. The hot water lasts for upto a minute maximum before going freezing cold again.
I have removed the front casing and cleaned out the clear tubes as advised to do after a quick google search of the issue. I have also had a Corgi registered technician out to have a look at this issue and he said it would be fixed, however nothing has changed since.
Any views on the issue are appreciated and if anybody knows a way to fix this issue that would be even better, thank you.
